View VRFs corresponding to Layer 3 (routed) VSN I-SIDs on either a Controller or a Leaf node.
Ensure that you enable DvR globally on the node.
- Select DVR.
- Select the L3–VSN tab.
- Optional: To filter rows based on specific filter criteria, select Filter.
L3–VSN Field Descriptions
Use the data in the following table to use the L3–VSN tab.
Name |
Description |
VrfId |
Specifies the VRF ID of the VRF corresponding to the Layer 3 VSN I-SID. |
Isid |
Specifies the Layer 3 VSN I-SID. |
VrfName |
Specifies the VRF name of the VRF corresponding to the Layer 3 VSN I-SID. |
InjectDefaultRouteDisable |
Specifies whether injection of default routes is disabled. |
